Didn't see this anywhere on here so here it is.
http://www.cobbforums.com/forums/showthread.php?t=44081
MBC (I have one for saleIs there any way at all to get any consistency in this boost system?
did you try them without the boost control solenoid?Well, even then I found some inconsistency. I tried two different boost controllers...still got spikes and boost cut. I'd be running 17 psi one day and be closer to 15 psi that night.
yes. I tried everything, trust me. About 4 different vacuum setups in all, all with the BCS capped off completely
any idea if these will work for an 09?
