I'll get final pictures, prices and specs this week, but the Front Mount Intercooler kit for the Mazdaspeed Protege we promised a few months back is ready to go!! Bell Engineering will be providing me with all the final details but it looks like everything will be according to the requests we fielded from you guys back then. Namely, you should be able to drop in a larger radiator (like from a protege5) with this FMIC.
Questions and comments are welcome!
EDIT :: Specifications and Numbers showing Improved Performance and Efficiency over Stock Intercooler! Pictures Coming!
Intercooler Pressure Drop /><O
></O
Measured at IC inlet and IC outlet. <O
></O
Measured on a non-stock boost pressure vehicle.<O
></O
Measured on BEGi 20 psi boost gauges (2).<O
></O
Gauges switched after midpoint of total runs.<O
></O
Gathered using either:<O
></O
Constant Speed, Full Throttle, 4000 rpm, 4<SUP>th</SUP> Gear<O
></O
Redline (0/-500 rpm), Full Throttle, Redline (0/-500 rpm)<O
></O
OEM MazdaSpeed Protege Intercooler Pressure Loss :: 2.28 psi
BEGi MazdaSpeed Protege Intercooler Pressure Loss :: 00.5 psi
Intercooler Temperature Drop<O
></O
IC temperature measured at IC inlet and IC outlet. <O
></O
Intake temperature measured at center of intake horn with air filter in place.<O
></O
Measured with Omega 781A Digital Thermometer.<O
></O
Gathered at full throttle, maximum boost, 60 mph, 3500-4000 rpm, constant speed/rpm with braking. Speed and load held until temperatures stable.<O
></O
Efficiency = 52.4%<O
></O
Efficiency = 87.2%
<O
>There you have it - an almost 2 psi increase over stock and over 30% more efficient than stock</O
