T TDRMP3 Member : Mazda Protege MP3 Jan 15, 2008 #1 i have 2 cylinders not firing i think because i have a bad pulse to the injectors is there wanyw ay to fix this or what?
L LordWorm Member Jan 15, 2008 #2 TDRMP3 said: i have 2 cylinders not firing i think because i have a bad pulse to the injectors is there wanyw ay to fix this or what? Click to expand... bad pulse? as in an electrical problem? check your connections. If that doesn't solve it, have the injectors tested and/or replace as needed.
