awr mounts Crazy vibration!!!!!!
The trick to the trans mount is to loosen the big black bracket the mount bolts into. There are 4 bolts where it secures to the trans and if you loosen them the mount will line right up and bolt in.
That's what I thought to but it didn't work. Had to take off the black mount that bolts to the transmission and use a spreader to spread it so that the mount would line up. It was a real pain.
^^ what he said. i had to buy a spreader because the minerva trasmission mount is too wide to fit in the bracket.
Minerva front mount is also a bit too wide, I had to put a pry bar in the stock mount location and open it up a bit to get it to go in
All the minerva mounts I installed (front, rear and trans) all fit fine, a tight snug fit but easy to slide in place. Only problem was I had to drill out one hole on the rear mount for it to fit.
