AWR MM question
Meydron
2007 Mazdaspeed6
I will be receiving the front and back AWR MM's for Christmas but i remember reading somewhere that you can get them in different stiffness. So my question is which stiffness do i get for my MSP since it is a daily driven car that only sees the track a couple times a year. I understand that my car will ride a little rougher but my stock mounts are shot and i have to replace them. So any feedback will be appreciated. Thanks.
I may not be correct , but the last time that i knew, AWR only had MM's for auto and manual tranny's. mabey the two are different in stiffness.I would get the stiffest kind though because it will be very helpfull to you and wont hurt your car any. you just gotta deal with all the vibration.hope this helps alittle.
Meydron, I just installed the front AWR MM (70 durameter, softest) and both of the side inserts (only one stiffness. So far the vibrations are barely increase from stock, but the car is WAY more solid. I highly recommend the 70 durameter mounts for the front and rear. I will be installing the rear 70 mount sometime soon.
Also, StreeUnit sells the front and rear mounts with the 70 durameter inserts already in them so you don't have to get them separately.
Thanks a lot for the info Spooled. Will do, just needed to get all the questions answered so i can tell my g/f what and where to get me for x-mas. Thanks again.
