I noticed a difference in acceleration, the FWD seemd to have more get up and go!
you've obviously given this a lot of thought, but i'd have to disagree with you here. FWD does not have superior in traction (safer) in the corners. its the simple fact of weight transfer. when you accelerate mid-turn (lets use a right hand turn, for example) your weight is transfered to the drivers side tires, front and rear fairly equally (assuming you aren't on the brakes, which is a bad situation anyway). upon acceleration the weight is transfered to both rear tires which is why you can put a vehicle right up to its traction breaking point but still gain more speed around the curve and keep it from losing traction. during this acceleration the FWD car will have a tendency to break traction in the front tires, usually the front right (i do this all the time in my FWD cx9). in a RWD vehicle you do not loose traction in the drive tires because the weight transfer is directly on the tires you are powering.Plus, if you are going around a corner, and let's say you lose control and the back end swings out, with awd, the rear wheels being driven will only cause further back end swing than fwd. Now supposedly the computer can sense which wheel of the 4 is slipping and applies power to the wheel with less slip. I don't see any advantage to awd, unless you live in a hilly area in the north half of the u.s. and the roads become snow covered more than several times a winter. Keep in mind, when trying to slow down, all wheel drive does nothing for you, you rely only on your brakes, so the only thing awd is for is acceleration on slippery surfaces so your tires dont spin. But think about it, with front wheel drive, if your tires spin, you do NOT lose control, because front tires spinning do not cause a rear end to slide sideways.... rear tires losing traction cause a rear end to slide sideways, so I want nothing to do with applying any power to rear wheels at any time.
What he said.. I live in the high desert of CA, I opted for FWD. It never rains, snow is an impossibility.. One less thing to break (I tend to keep cars a long time), plus it gets a little better gas milage. I didn't even see many AWD models on the lots around here - all FWD. Total opposite when I was helping my sister shop for a Mazda back in Ohio - all AWD CX-9's and no FWD models on the lots.
Couple times I went to Big Bear, chains were mandatory for AWD vehicles anyways. They were only optional for 4WD + Snow Tires those days.
AWD is great for accelerating in the snow, but it doesn't do anything to improve braking performance or cornering. Thats where traction control comes in, and the FWD model has it too. I'm not even sure if I still lived back in Ohio if I'd opt for AWD - FWD with snow tires always served me well, especially since the snow tires help with braking and cornering and AWD does not.
lets also look at any race car. the majority of race cars today are RWD. next would be AWD. not many are FWD unless they are in a specific class based on the vehicle's original design. why is that?
personally, i'd rather control an over-steer situation over an under-steer situation any day of the week. granted, the majority of drivers are not trained in any way in defensive driving or any type of 'control' driving where you need to recover a vehicle that has lost traction
l
