AVC-R install help
tomsnatchez
Black MS3 GT
I have the factory nav... anyone know which wire on the DVD player is the signal for the VSS? trying to hook up a speed signal wire for my AVC-R and would be easier to tap from the back of the dvd player instead of coming all the way from the cluster...
The factory nav does not have dvd, next the factory nav calculates speed based on GPS signal (someone correct me if im wrong).
Last do a search in the car audio or how to section, there was someone that installed the Pioneer Avic z1 and used a wire from the back of the cluster for the VSS signal. should be an easy find.
side not, the AVC-R is 1 ******* expensive boost controller. alot of the features you'll probably never use. good luck with everything.
