- 2008 Mazda5 GT
Just came across this very helpful aux cooler thread.
http://www.yotatech .com/f2/transmission-cooler-mounting-thoughts-interesting-discovery-215128/
In short:
1)You want to mount the cooler as close to, but not touching by using the supplied hardware, the condensor. This allows the aux cooler to reap the benefits of the radiator fan (or AC fan but longer hose) - Genius! It's like having the e-fan aux cooler but not as effective
. This is benaficary on hot days driving at low speeds where soly relying on air cooled would not help as much. When fan kicks-in, it pulls air through the radiator and if the aux cooler is close enough - bonus!
2)Zip ties are a good solution but only through condensor, not both condensor and raditor.
3)I need to RTM and be weary of air in the system. You WANT the transmisison pump to build pressure and avoid air. Looks like Mark did it right.
In short:
