Autoweek Mazdaspeed 3 review
Mazdamia
2003 Mazda Protege5
From Autoweek:
2007 Mazdaspeed Mazda 3 Grand Touring
[URL="http://cwimg.sv.publicus.com/apps/pbcsi.dll/bilde?Site=CW&Date=20070313&Category=BLOG06&ArtNo=70309007&Ref=AR&Profile=1004&maxw=490"]http://cwimg.sv.publicus.com/apps/pbcsi.dll/bilde?Site=CW&Date=20070313&Category=BLOG06&ArtNo=70309007&Ref=AR&Profile=1004&maxw=490[/URL]
The Mazdaspeed 3 may be the best bang-for-your-buck ride out there right now.
By JONATHAN WONG
AutoWeek | Published 03/13/07, 9:05 am et
AT A GLANCE:2007 MAZDASPEED MAZDA 3 GRAND TOURING
BASE PRICE: $24,550
AS-TESTED: $24,550
DRIVETRAIN: 2.3-liter turbocharged I4; fwd, six-speed manual
OUTPUT: 263 hp @ 5500 rpm, 280 lb-ft @ 3000 rpm
CURB WEIGHT: 3153 lbs
FUEL MILEAGE (EPA/AW): 23/22.2
OPTIONS: None
When the Mazdaspeed Protg came out in 2003, it became an instant hit with enthusiasts. Its exceptional handling had some comparing it to the Acura Integra Type R, a front-wheel-drive performance benchmark, thanks to a great suspension set-up and a limited-slip differential. However, the mere 170 hp from the turbocharged engine left some wanting.
Thankfully, there are no such worries with the Mazdaspeed 3. In fact, power is the last thing you need to worry about. A version of the engine found in both the Mazdaspeed 6 and CX-7 makes the Mazdaspeed 3 a screamer in a straight line.
In our log, Phil Floraday said he thinks this would do well in an autocross. It has the snappy steering response thats perfect to get around a tight course and the suspension offers minimal roll and little dive, yet is comfortable for everyday affairs. The brakes are also strong, letting you dive into corners that much deeper. The one thing that had me on the fence was all the power from the turbocharged four going to the front wheels.
Driving it helped calm most of my fears. Hammering it from a standstill, I got some wheel hop, but Im confident that in warmer weather the 18-inch rubber will hook-up and get most of the power down, especially with the help of the torque management system.
The torque management system is the key and is what helps tame the Mazdaspeed 3s power and makes it usable. To take the edge off of the power spike you get when the turbo hits peak boost, it will bleed boost through the wastegate in first and second gear to help prevent wheel spin. The system is also active when there is enough steering input for wheel spin, thus reducing torque steer at the same time. Throw in the limited-slip and I agree, its a great choice for the autocross and occasionally track day.
In the end, if you combine the cars performance, hatchback utility and under-$25k pricing, I think you are left with what might be the biggest bang for your buck. Build quality is nice both inside and out, the interior is comfortable with nicely bolstered seats that latch onto you, and it has a nice-sounding Bose stereo system.
I would have a tough choice deciding between this and a Honda Civic Si, though. The surge you get from having boost is nice, but I usually tend to side with a high-strung naturally aspirated car for the superior throttle response and linear power delivery. Tough choice.
