Automatic Transmission Question
lifeline830
2003 Protege 5
I recently experienced a rougher shifting feel in my protege. I took it to a tranny specialist and he drove it, and basically said there isnt a problem and he doesnt see a future problem, and his recommendation was i MIGHt want to have a tranny fluid flush. Has anybody experienced this problem? My car is a 2003 with around 53K.
check your engine mounts, could very well be torn. no modifications done to the car i imagine?
At 53K miles, you're only about 7k miles shy of needing the second fluid flush. Is this the factory fluid you're still using?
Have you fixed your problem or found what's causing it? I just bought a 2003 p5 yesterday and it's a little tight when going from N to D.
Thanks
