Auto Turbo Timer install
joe's_speed3
08 mazdaspeed3
Alright. So i bought an HKS Type I Turbo Timer and started the install (slow day at work).
I Have searched but i havent been able to find the wires for the RPM and VSS.
I would like to connect these to use the full functions of the timer.
Any help is appreciated. Looking for wires close to guage cluster or at ecu.
There is no VSS wire unless you have the NAV. You can tap into the back of the instrument cluster for it, but you have to create a contact for the connector. There is also no conventional RPM wire. You can tap into the signal going to one of the coil packs, but it will read slow unless you can set the TT for a 1-cylinder engine. All this stuff goes over the CAN bus. This has been discussed here many times, you should be able to find it with a little searching around.
