I'm planning to use the method where I flush the transmission myself (using the oil cooler line, it's on this site somewhere). Anyhow, is it really necessary to change the transmission filter that's accessible by removing the transmission oil pan? I see NOTHING in the owners manual about the transmission fluid, let alone the transmission filter.
Frankly I'd rather not do the filter as I don't need to drop the transmission pan at all with the flush procedure. But, if it's 100% necessary and if I would be rediculously stupid not to do it, please let me know (with a reason) and I'll pick it up. Unfortunately the filter kit is $35 locally and that's as cheap as I can get it for here in Canada.
Thanks,
Eric
Thanks,
Eric
