Attn: Big guys and Miata
Mr. Win
Contributor
Looking to buy a project car and I am considering a Miata but I have concerns with my size and the car.
6'3'' 210ish 33inch waist.
Other consideration is a LT1 RX7.
33" is not such a big waist. You may have trouble with the height. You'd definately need a racing seat, probably bolted to the floor, all the way back.
There's much more room in an FC. I've had both.
Haha, you are uber tall! Thank God for me fitting just *right* in my Miata. I think you can make it.
Have you even sat in one before?
I am 6'2 240ish and I drove a 93' miata just fine. But then I got into a new on and my head stuck out an inch over the top. But if you get a racing seat to the floor you should be more than fine.
Your weight should be just fine. My brother is 260ish and he rides in mine without problems...although I prefer it when he doesn't. ;)
Best thing to do would be to go for a few test drives with the top up and then down and see how everything feels.
I sat in the new MX-5 at a dealership and I was surprised by how much leg room was in there. I had to move it up 2 notches closer from the farthest back position. And I'm six foot. So you should be good.
My impression is the newer ones were bigger. I can fit in the new guy. Edit: Of course the top was down at the dealer.
I'm more worried about the 96-97 era. I like sitting up a little close I feel like I have better control over the car and the pedals.
Its hard to find one to sit in around here... I'll have to trek around in order to find one and I don't want to start bothering guys until I can say to them "I'll take it." Finances are almost in order.
I was 6'0 220lbs with a 36 inch waist (I slimmed down to 180lbs thankfully) and I fit into a miata just fine.
I'm 6', 200lbs and I have no problems with my NB, the NA seemed to have a little bit more room. I think the length of the legs are more important. I have a longer body so my legs are comfortable, my father has longer legs than I and he starts running out of room under the dash.
NC>NA>NB at least in terms of interior room. The NB's are kind of cramped inside, especially if you've got wide shoulders. I don't, and I find my Dad's NB kinda cramped.
NA>all in terms of feel. I can't otherwise explain that statement.
Hmm interesting, I'll have to make a trip to the dealership... I'm bigger then I used to be so if I still fit in an NB then hopefully the NA will be a little more comforting. Foolish do you know your jacket size? I wear a 46-7.
Jacket size? I have no idea. I'm 5'11", 178 ish. I'm acutally not a big guy, but I've been around Miatas and Miata owners a lot, and generally people complain that the NB is kind of cramped. I had an NA, my Dad had two NA's and now has an NB and my father-in-law has an NC.
I'm not super scrawny, but I'm far from burly and I find the NB cramped around the shoulders, just FYI. Clearly, you need to go try some on!
fatass. (poke)
