ATF, Rear Differential Oil , Transfer case fluid change - Videos & Tool sources
kulkarnipb
2012, CX-9 Touring
I received request to share sources to buy tools/oils for each of the videos I created . So I am sharing all the details. Hope this helps for the DIY projects. These tools/oils are for reference and information only !
*************** ATF Change *******************
Thanks cpb406 and 'Pootie Tang' for showing ways on drain and flush on the below threads respectively -
http://www.mazdas247.com/forum/show...luid-Changes&p=6326764&highlight=#post6326764
and
http://www.mazdas247.com/forum/showthread.php?123855296-Home-transmission-flush-success
Video -
3/8 ratchet
http://www.homedepot.com/s/3%2F8%20ratchet?NCNI-5
OR
https://www.amazon.com (commissions earned)
1/2 ratchet
http://www.homedepot.com/p/Husky-10...tchet-H10012RAT/206034100?keyword=1/2+ratchet
OR
ATF
( at least 7 bottles of 1 quart each )
OR
17 mm bit hex socket
T-40
http://www.homedepot.com/p/Husky-T55-Torx-3-8-in-Drive-Bit-Socket-H3DHBST55/202940696
If you don't have dip stick for ATF ( if I am not wrong CX-9 - 2011 and onwards ) , then below tools are needed too -
3/8 - 18 inch extension
T-55
http://www.homedepot.com/p/Husky-T40-Torx-3-8-in-Drive-Bit-Socket-H3DHBST40/202913547
Oil Pan and funnel -
Buy from dollar tree or any dollar shop or any other shop
Vinyl Tube to attach to funnel and attach clamps ( if you find these in a dolalr shop then awesome, otherwise goto homedepot ) -
http://www.homedepot.com/p/Sioux-Ch...-D-x-2-ft-Clear-Vinyl-Tubing-HSVSP2/204407884
http://www.homedepot.com/p/Everbilt-1-3-4-in-Stainless-Steel-Clamp-6720595/202309386
************ Rear Differential Fluid change ************
Video -
Oil
( 2 bottles since required quantity is 1.1 quart )
Oil Pump
OR
http://www.walmart.com/ip/Gas-Oil-Siphon-Pump/39105532
OR
OR
http://www.homedepot.com/p/Arnold-Siphon-Pump-Kit-490-850-0008/203051321
Oil Pan -
1/2 ratchet
OR
24 mm socket
************ Transfer Case Fluid change ************
Thanks to avidien for creating original thread with lot of information at - http://www.mazdas247.com/forum/show...Changing-CX-9-transfer-case-gear-oil-(photos)
Video -
3/8 ratchet
OR
Oil -
http://shop.advanceautoparts.com/p/...01/7070083-P?searchTerm=royal+purple+gear+oil
OR
OR
http://shop.advanceautoparts.com/p/...t.-102490-98fs32/7070076-P?searchTerm=75w-140
Suction Transfer Pump and since Pump's power card don't reach to car's battery easily , use jumper cable as extension( if you don't have already , buy it)
Oil pump -
OR
OR
Awesome post kulkarnipb!!! Thanks for all the good work, I know this will be very helpful to a lot of people.
Question, for the rear differential, do you fill until oil starts dripping out of the fill hole like the front transfer case?
Thx. Yes, till it overflows.
Sent from my SM-N910V using Tapatalk
