- 2002 BJFW, 2007 BK3P, 1979 SA22C, 2005 BK3P
dukefanmaz3 said:i have another ? what is axela?
axela is the japanese name for the mazda3
Reffoxel said:Your graph looks like it needs more timing.
Here's some work my tuner did with a 2.0 engine on 8lbs, that isn't perfect but that was due to the fact that the stock fuel pump has problems above 380hp on 93octane.
Reffoxel said:Not an FS motor. It's a 11:1 compression, bone dry stock Honda 2.0L
TurfBurn said:That makes more sense... 11:1 and the cam profiling etc makes a lot more sense... I was going to wave a serious BS flag if you were claiming that on an FS motor since the best anyone is yielding is around 15 horse per psi.. maybe 16... what is the base horse of that motor (aka how many horse per psi were you pulling out of it... 18-20 hp/psi is usually beyond good and typically unachievable based on my knowledge)
TurfBurn said:Why is that the K series motor is doing that kind of output for the boost when the B series dynos I look up require around 12-14 psi to put down close to those numbers... granted, it is .2 liters different... but was curious if there was something particular between the two that caused it... was it with race gas to run that kind of compression etc to pull that? or was it 93 (I'm seeming to think you mentioned 93).
Reffoxel said:the vtec is about 3-400 rpms low, anything higher it just blew the tires off when vtec hit, the jump was more than insane shall we say. (btw this is Ref's tuner talking aka roommate Justin from SCI Motorsports)The car is on k-pro, it enable the user to tune the optimum hp and tq per 10 deg. rotation of the camshaft then after blending the curves take on a whole new live, by far one of the very best softwares I have ever worked with.
TurfBurn said:I found some other dynos now... non-intercooled K20 at 7 psi did 258 horse... so 8 psi and cooled... I can see it picking up a fair bit more...
Reffoxel said:the compression always helps. I have always been a huge fan of compression and boost. Nothing unsafe about it as long as you understand timming. It was on 93 oct. I am rather embarased with the aggresive dips in the curve in the higher rpm range but no aftermarket pump=no more power.
Reffoxel said:That is a turbo kit my partner chad and I designed. It is by far the tits when it comes to k series kits. I hope to duplicate great results with ref's kit and tuning. We will be tackling his car with unichip and we willse just how far we can take it. I have done good things with uni and I hope to do as well if not better with it on his car.
Reffoxel said:I like at a min. 9.0:1 but most are around 9.5 to 10.5. and we run up to about 25 or so psi. Chad's car (my partner is about 10.4:1 and right at 25 = 627/468. on a beefed up bottom end).
