Apex J pipe w/cat or Corksport power series?
Corksport Exhaust or Apex J pipe w/cat
  • Corksport Exhaust
    Votes: 2 66.7%
  • Apex J pipe
    Votes: 1 33.3%
  • Total voters
    3
I have the Apex j pipe and it is the best investment I have made for the speed yet. The service was excellent and they answered all my questions. It is a quality product.
You can't really compare a catless exhaust system with a catted downpipe.
I was going for the corksport but no one can answer my question about the MIL eliminator. I just need to know if I have to take the car in for warranty issues and I have to put the stock exhaust back on will the MIL eliminator make my car run bad with the stock exhaust with both cats. If i can't get an answer I am just going to get the catted DP just so I won't have to worry about it.
As long as you install the MIL eliminator correctly, you shouldn't see the CEL light. The only thing an exhaust mod can mess with is your exhaust warranty. You should be fine with the corksport. And besides, you will see a much bigger increase in power versus just the Apex catted DP.
EDIT:I'm not positive, but the MIL eliminator should still keep the car running fine even if you put the stock exhaust back on. Basically all it does it bypass the O2 sensor, making your car think it's still working right. The MIL eliminator should bypass the fact that the cats are or aren't there. Make sense?? (confused)
That makes total sense. Thank you so much, I have posted that question on here and got no responses. So Corksport will be ordered this week. Thanks again for your help.
