anyone running AP accessport with Fujita CAI?
evo'skickass
2007 Mazdaspeed 6
Like the title states...I'm about to get the Cobb AP and have a fujita CAI, I was just wondering if there is going to be a major difference in running the funjita intake vs. the Cobb SF or CPE- intake ? And also if there is anyone that has a fujita intake that is running the AP...your thoughts and if you have had any problems?
thanks
I would check out the map notes. They are pretty specific on what intake you use and what maps you run. Not all intakes work the same. Different maf housings, air straighteners, etc...
all intakes will not work the same. the stage 1+SF map is only good for the cobb sf intake and the cp-e intake. they are currently workign on a ms cai one and quite possible a fujita one. cobb sf has air straighteners and the cp-e one has good maf placement so there is good air flow across the maf. its been said ms and fujita ones can have some turbulent air skewing readings at times. so either go with just the stage 1 or stage 2 depending on whether you just have stock downpipe or you have a test pipe or downpipe.
http://www.cobbforums.com/forums/showthread.php?t=41842&page=4
see this is what i've been told also and was kinda lost when the first response said everything is the same its all good....along those lines.
