Anyone need any parts???
infrared5
Protege5
I recently blew my stock FS-DE, and finally got my new one in. But now I have a motor sitting in my garage with alot of good parts on it. Does anyone need anything? Please let me know and I can setup an ebay auction for your part. I also have the capability to powdercoat in my garage, so if you want I can coat parts as well. You can check out the current auction for the intake manifold on ebay at
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7905162137
Ive been coating for about two years now, and currently coat for a shop here in town. You can view my new powdercoated motor at
http://www.cardomain.com/id/adzamp5
I blew a hole in the block (old motor), so its no good, but I still have 3 pistons, rods & rings, crank, intake and exhaust cams w/ cam gears, sensors, valves, timing belt, head, pulleys, throttle body, coil packs w/ plug wires, fuel rail, etc. I also have a set of front struts with ground control spring perchs installed (only perchs), stock springs, top and bottom grills, stock clutch, flywheel, etc. If you need something let me know, ive got way too much to list, so just ask.
nope, it was wet. But the jet got twisted up and was spraying straight back into the manifold, so all the nitrous was going into cylinder one. It melted the plug, shattered the piston, twisted the rod, and put a hole in the cylinder wall and the block. Sh!t happens! If anyone wants something, give me a definate yes, and I'll put it on ebay.
Its hard to avoid this problem with the way our intakes bend so sharp before the throttle body, I would reccomend direct port in the future. just my $.02
What color would you like the fuel rail? If anyone wants something powdercoated, I'll need a few days to get it cleaned and coated.
Also, does it have to go on ebay? Cant I just pay you direct? Ebay kinda defeats the purpose since it will allow others to bid on it?
Pe@ce
Ok, the valve cover is already powdercoated, its the silver one with mazda logos in the pics on my cardomain site (it can be stripped if you want). The throttle body is the one that came with the salvaged motor, so its not as clean as the other parts. Its got some splotches on the metal but that could be cleaned off. I took the throttle body apart the other day to prep it for powdercoat, so its just the actual metal body now. The black sensor on top of the throttle body (black cylinder) was broken, but everything else will come with it.
Yeah, the head got pretty jacked up, the bottom side looks like someone took a jackhammer to cylinder one. I really dont think you want the complete head, but if you want any of the guts (valves, springs, etc) let me know. I almost bought a valve spring compressor the other day to start taking it apart, but didnt. I'll give the head a hard look tomorrow to see what I'm gonna do with it. But im not gonna sell someone a junk head.
