anyone know the specs for the stock bellhousing bolts???
719prottege
03 msp
i am just trying to get my engin on my engine stand, but the stock bellhousing blots are too short. i have went to ace and fastenall with the bolt and they both gave me the wrong thread pitch.... anyone know for sure what it is?
I usually just pick up some 3/4" allthread, and a bunch of nuts and washers, and cut to my liking.
So, you're just wanting the thread and pitch of the bolt? Or are you needing the grade, length, and cap size? Or are you needing torque specs for the bellhousing....
...i have went to ace and fastenall with the bolt and they both gave me the wrong thread pitch.... anyone know for sure what it is?
id say hes looking for the thread pitch... i dunno, maybe its just me... sorry man cant help you, but if you go to the store with the bolt why not find what nut fits on it and then use reverse engineering and use that nut to find the correct bolt pitch? i used to work at a hardware store so matching bolts was a thing i had to do. or you can hold the two bolts threads together, if you cant pull it apart then its the correct pitch.
here is an amateur drawing of what i mean. |= head of bolt, ~=thead
..~~~| pull in --> direction
|~~~ pull in <-- direction
M14x1.5 is the thread and pitch
It may depend on your engine stand, but a 90mm bolt worked great for my stand.
