anyone have a descent map for me by chance?
lncatch
2003 MSP Metalic Black
so i installed my new turbo today...well over the last few days. Just looking to see if anyone has a good map for me to start off with for the tuning. I have CAI, relocated MAF, GT28RS, 626 intake manifold, perrin exhaust, and the split second ATC. I have the wastegate set up to the stock one running about 8 psi. anyone thats got some good info would be great. Thanks
If you don't have a wideband, your best bet would be to run off of the stock supermap for now. If you do have a wideband, run the stock supermap and tune off of that map to your specific mods.
the SSAFC and SSFTC are exactly the same. The only addition is the SSFTC has timing control to an extent. Other than that, they are the same.
yeah but can you turn the timing control off? idk im just going strait to a haltech. just looking out
no, you cant turn it off, its automatically set to run the standard timing unless you mess with it, its set up pretty much like the fuel map except it starts at 0
the fuel map is on map A and the timing map is on map B. Both maps are on both the AFC and FTC. But on the AFC, map B shows all zeros since it doesn't have timing control. The FTC uses map B for timing control. I don't think you can turn it on or off. You just use the timing map as you need to but you really don't need to use the timing map until you are running more boost.
but if you dont do the timing it will automatically use the oem timing? im trying to learn so sorry lol
