Anyone had this problem?
CG12
14 CX5 Touring with Tech/Mnrf
Was driving my brand new 14 Touring w/ tech the other night and then it happened again this morning:
All of a sudden all the warning lights and messages popped up on the screen and speedometer dropped to 0.
Tpms, scbs, check engine, check key, airbags - pretty much everything. BUT the car kept driving fine.
Shut the engine off and start back up, only the check engine light is on. The other night after a few stops and starts of the engine it cleared the check engine light.
So it did it again this morning, and I drove right to the dealer. Got a loaner right away and they will be looking at it.
Anyone else seen this?
Mine has been normal (everything functioning as intended). It sounds like a potential loose ground. I wonder if the trailer hitch pigtail installation was not done properly?
Got the cx5 back this afternoon. They think they found the problem. The "room fuse" was apparently making an intermittent connection in the fuse box. When it was originally inserted the blade from the fuse pushed its holder out of alignment. Here's hoping that's what it was.
