+15w30
I really enjoy getting your input when it comes to our P5!
Best reason: the factory manual says to use either 10W30 or 5W30. There is no reason to use any other type of oil unless there are other circumstances present.
Wouldn't you burn off some of the thinner oil when your engine is cold? Your pistons expand a tiny amount as you heat up the engine. If you have an engine with alot of miles on it the tiny gap lets thin oil burn off much easier. I normally use 10w30, and switch to 5w30 for Dec, Jan, and Fed.
It's thinner oil, if that doesn't spell it out for you (google).Do you have any supporting documentation for the claim that it provides less protection?
