Anybody put wheel spacers on their '14 - '16 Mazda6?
Mazda6 GT, MX5 PRHT
I don't want to buy a set of wheels with a different offset. I also don't want to lower the car. But, pushing the stock wheels out towards the fender of the car would look better. I did this on my MX5 and it looks great (but I also put coilovers on). Has anyone put wheel spacers on? If so, what thickness without wheel stud replacement or modification? Where did you buy them?
what size spacers did you install to your MX5? where did you get them?
i want to install them to my MX5 :D
25mm. H&R makes them. I did have the fenders rolled as well. If you put 20mm in I think you could avoid rolling the fenders. The kind I bought bolt to the hub using the original studs and the spacers have their own studs that you bolt the wheels to using the original lug nuts. But, a 20mm spacer may also cause the original studs to contact the back side of the wheel when you bolt it on. I know with 25mm you won't have that problem. I found somebody local with the correct tool to roll the fenders and he came to my house and did it for $80.
