Any pix of MS3 running 235/40 on stock rims?
Like others have said 235 on a 7" wheel may not really be that great or beneficial. I would stick with stock tire size or 225/40 for 7" wide
Best possible example is the RX8 wheels. 18x8 with a ~50 offset, they fit like a glove and look hot. Should have been stock on this car!
I've started looking into these alot; They're an inch wider, have perfect fitment, are reasonably priced (if you find an RX8'er that has bought aftermarket rims), are roughly 4 pounds lighter per rim than the ms3 stockers and look better (not like that's hard), but still have that factory appearance (I dig the sleeper aspect of our cars). They also look like they'd be easier to clean. I think when my OEM bridgestones are done I'll be getting a set of them!
After much reading, I gave up and went with a larger rim (7.5" running 235s). I really like the choice. The wider tire feels much more stable and I burn a lot less rubber between 2nd and 3rd...
