Any photographers in here?
It's a little tedious photographing with it. You have to focus and meter without the filter on. Then switch to manual focus or lock your focus, attach the filter and then do the long exposure required usually with bulb setting. There are charts out there or there's the math work to calculate your exposures properly. Most will set the ISO to 100 and stop down to f/14 or so and use a chart to give exposure times. An example is with your ISO and f-stop selected (and your metering done) would be if you had an exposure of 1/125 sec ( using ISO 100 and f/14 ) calculate 1/125 X 1000 (10 stops) = 1000 over 125 and then divide = 8 seconds . . your exposure. Simple eh . . . Hope this made sense.
print this off or write it down and stuff it with your filter.
1/8000 = 1/8
1/4000 = 1/4
1/1000 = 1/2
1/500 = 2
1/250 = 4 .
1/125 = 8
1/60 = 16
1/30 = 30
1/15 = 60
1/8 = 120
1/4 = 240
1/2 = 480
1 = 960
2= 1920
4 = 384
First column is your meter reading using NO FILTER. The second column is the adjusted exposure you need to use.
I don't understand that math, but somehow you came out with the right answer. The easiest way for me is this: adjusting by a stop of light means either doubling the amount of light or cutting it in half. in this case, for a 10 stop ND filter, you're cutting the amount of light in half ten times when you add the filter. to compensate, you must cut the shutter by half ten times to make up for it.
Example - If you meter a scene and discover that your shutter speed should be 1/4000sec, you double that ten times.
1/4000
1/2000
1/1000
1/500
1/250
1/125
1/60
1/30
1/15
1/8
1/4sec
so with the filter, your exposure is 1/4sec instead of 1/4000.
if you start with a 1 sec shutter time, you go to 2,4,8,16,32,64,128,256,512,1024 seconds.
hmm looking now, our math is different... I come up with an additional 60 seconds on that last one. interesting.
That's the attachment size for the lens. Check the front of your lens for the number in mm that you need before you purchase a filter.
Oh ok... Well I've two lenses one being the 18-55mm that came with the d40, the other is a 55-200mm... Let's hope there both the same mm
Edit: lucky for me the 55-200mm lense came with a sunpak.. And it had 52mm on the ultraviolet filter.. So I tested it on my other lense and it fit.. So looks like I'm buying the 52mm filter.. Once again thanks for all the help..
Everytime I ride by the Fisker dealership and see the same white car you have pictured, all I can think about is that mustache on the front of it
no Fiskers have blown up anywhere that I know of... running dependably, that's another matter. They are getting much better though. Especially for a brand new car company that has never manufactured anything before.
I love the smile on the front of them. looks like a catfish or the cheshire cat or something.
Finn McMissile
