Would an 8 inch rim fit a 2007 Mazda 5? What would the offset have to be if it were to be an option as well. Everything I've seen says 7.5inches is the right width. Just wondering because I have a chance to get a rim and tire package. Thanks
IIRC, you can certainly fit an 8" wide wheel. Depending on the look and what you want to do with your 5 will determine the offset. If you're looking to just do a bolt on upgrade without having to roll your fenders and just not deal with rubbing, then stick to an offset no lower then +48mm.
