http://www.newsday.com/classifieds/cars/ford-issues-another-recall-of-new-escape-1.3958294
Ford is recalling 7,600 new Escapes to fix coolant leaks that can cause engines to overheat or catch fire.
The recall affects 2013 models with 1.6-liter four-cylinder engines.
Plugs in the engine may not have been installed properly and can fall out while the motor is running. Coolant can leak and cause engines to overheat.
Dealers have repair parts available and owners should make service appointments as soon as possible, said Ford spokeswoman Marcey Zwiebel. Ford will fix the problem for free.
It's the third recall in less than two months for the completely redesigned SUV, which also has had problems with fuel lines and carpet padding. In July, the company recalled 11,500 Escapes to fix lines that can crack, leak and cause fires. That same month, Ford said it would recall more than 10,000 of the vehicles to fix carpet padding that can interfere with braking.
