alignment
spicey
Hello all,
I'm a novice to cars(first school and now work contributing to this). I have a problem with wheel alignment with my car having all the signs- steering wheel off center,car tending to move towards right, difficulty steering with car swaying (and i've noticed once,swerving to right on braking) with now wear and tear on the inner sides of my two front tires. Unfortunately I dont know if this problem is new( i was a bigger novice when i bought my car and wasnt using it much till the last few months) or simply an old one gotten worse with the wear and tear of the tires especially. I was reading that only toe-ins can be corrected properly and not camber( sounds like a camber problem to me- i've been reading some) or caster. So, if I've goofed up and my car always had an alignment problem( now gotten worse), can I get it fixed. Any ideas on what could cause the camber problems? Whom should I approach. My car has about 15000 miles and its a 2003 mazda.
Take it to the dealer. You definately have a problem, but you are under warranty so it shouldn't be too much of an issue. Is sounds like a bad part, more than just an alignment. Have you ever hit a curb pretty hard? You could've bent a tie rod or something. I don't know too much about suspensions.
