Jmterminator
- 2006 Mazdaspeed 6
Hi guys, i will be installing my H&R springs probly next week. I wanted to know what alignment specs should i have the alignment shop set my car to? I want good handling and good tire wear. Also i bought the spc adjustable ball joints so i guess i might as well install them at the same time. My question on those is should i put the ball joints in so i will have negative camber or positive camber. And should i just use a ball joint separator to take the old ones out and put the new ones in?
Thanks
Thanks
