Alignment Spec
azeli73
Contributor
2002 Protege 5 Turbo
Does anyone have the alignment specs. for 2002 protege5? I want to take my ride back to where I got it done because I am getting really bad wear on my tires.
They warranty the work so they better fix it.
<b>Please help</b> I want to compare notes!
Here hope this helps..
Front left and right
Camber -1.08 0.2
Caster 0.9 2.9
Toe -0.10 0.30
Front
Cross Camber -1.5 1.5
Cross Caster -1.5 1.5
Total Toe -0.20 0.60
Rear Left and Right
Camber 1.6 0.4
Toe -0.10 0.30
Rear
Cross Camber 1.5 1.5
Total; Toe -0.20 0.60
Thrust Angle -0.80 0.80
This os what is on a read out of what I got back from Mazda.
This for the Mazda Protg 2002 Sedan and 5, with 16 rims
Thanks!
I'm going to compare notes with their print out to these. I'll post my results
So these specs.. Is this what it should be on these cars instead of everything being equal or almost equal..
And is this with weight in the back, full tank of gas, driver or what?
How did you come up with these specs.. Cause I just got my car aligned after lowering 2" and he tried to make everything equal or almost equal and it seems to be pulling to the left..
Also he sais I need shims and camber kits to change the camber.. Is this true or B.S.?
Thanks.. Later
