Airmack said:
Sorry, but I am a little new to this... Does the order of what I get matter for the most gains?
While it technically "does not matter" what order you get your mod's in, I would sit down and really think about what you are trying achieve out of the car. Drag Racing? Road Racing? Auto-x? Street Driveability? Reliablility? Show? The mods that you go with should match the goal.
For instance, if you you are going for drag racing or road racing, then I would definately say go with a front mount, becuase you can go larger on the turbo. You'll have greater turbo lag, but in those applications, you don't necessarily need the power down low.
Now if it's auto-x, then stick with a smaller or stock turbo and get an upgraded TMIC, as you'll want to be in your turbo's "sweet spot" in low and mid range.
If it's all about show, then by all means, go FMIC.
Also, I wouldn't buy into the "this oil adds 10 HP" and "this flitsamajigthing Valve gives you 20 HP" Unless you've seen dyno charts to prove beyond a doubt that those parts do give you that amount of HP at the wheels, then don't be surprised when you dyno after all these "20 hp" parts and you've only got 13 WHP combined from them.
My .02
