aftermarket 19" wheels
Nice looking wheel, but I believe the bore is incorrect for CX-5. Someone else will be along that knows more about wheels than I do to verify or not.
I am looking at getting these 19 inch wheels for my cx5:
http://www.fastwheels.ca/productinf...-gs+2.0l+skyactiv+(traction+avant)_s_pp&dm=19
Will I have any fitment issues with these? They are an inch wider than stock 19s, but I also noticed that the offset is 45mm instead of the stock 50mm (from what I read on this forum). I'm guessing this is to compensate for the slightly wider rim.
The bore is larger; not an issue. This is normally the case with aftermaket wheels. All you need is a set of $10-20 centric rings sized 67.1 (our bore) to 72.5 or w/e the bore is. I would recommend getting ride of the poopy oem tire for something wider and grippier. Also, +45 will look waybetter. You don't want aftermarket wheels that are pushed in like an old pickup truck.
Similar Threads and Articles
