After CPE Cold Air and Forge BPV Less Power?
Win
06 Mazdaspeed 6
Hey guys well i installed a CPE Cold air and a Forge BPV and now it doesn't seem like it has as much power as when it had all the stock piping and BPV on it. It doesn't feel as if it pulls as hard. Is this possible? Do i need to take off the Negative Batt cable and let the comp relearn the New Paramaters? Any suggestions.
Double check all the vac lines one might be unplugged. Sometimes things get pulled off without even knowing. Trust me it happens all the time. Resetting the ecu will definatly help.
Thanks guys i'll reset it tomorrow while im working on my other car. I'll go over everything also to make sure.
Well i found the TIP clamp loose. I could loosen it with my finger. I also found the Boost tubes to be relatively loose so i grabbed a 1/4 drive and a deep socket and snugged them up 1/4 turn past snug. I haven't even reset the ECU yet. I took it for a drive and it feels to hold boost better and feels better. I will probably be ordering a Corksport TIP in the next few days. I wish they made a powdercoated Black one though so it would go with my CPE Black Cold air and black Forge BPV. Although PG has Black Powdercoat for there's. HMM
may be cheaper and go with your theme but if you order from them be careful, I believe i read it from tunersteve or someone that they had a pg TIP and it had metal shaving or something inside the tubing so just inspect it really well before installation. You dont want that s*** in your engine lol
