durring WOT your looking for mid 13 to low 12. @ idle and cruise 14.7 and durring decel youll see way lean. the dash hawk is not set up for what you are wanting to do there is not a way for the alerts to come on when car goes into closed loop.
at WOT, it also depends what your RPM is...on the stock ECU, i'm used to seeing 13s up to like 4k rpms or so...then down to 12s from 4k-5k and then down to 10s and 11s after that. it really depends on what gear you're in too...=/ basically, if you drop down to 11 or lower at high RPMs, you're running pretty normally...=d
