Advance timing mod on a 99 miata
Which CAS are you referring to on the 99. The CAM Angle Sensor or the CRANK Angle Sensor.
You'll need to go with something like THIS, but modified to advance the timing or modify your existing one.
the only way i heard to adjust the timing on a 99+ car is not advisable. it basically intails wallowing the holes on the crank sensor to allow for some adjust ablitiy. it works if done right. i saw a stock 99 miata with just a intake/exhaust and timing put down 128hp at the wheels. it was at 119 before the timing mod.
