If anyone here has a ACT clutch and has noticed a "squeek" upon engaging the clutch, I learned something new last night from MazdaManiac.
Squeek: I always thought there was something wrong with the clutch. I found out that the squeek is comon for ACT clutches. So if you got that problem it is nothing big. It is the Pilot bearing and the Input shaft alignment that causes the squeek. Has nothing to do with the Throw out bearing, which is what I thought!
Pedal Stiffness: I also noticed with my ACT that some days the clutch would be really soft, and grab real high on the pedal. It just seemed to vary everyday, but the clutch was grabing like it should. Well I also found out that it is a normal issue. The suspected reason for this perticular problem is 1) The slave cylinder is so close to the exhaust mani, and acually causes the fluid to boil (blackish / brown fluid is a sign of brake fluid that has boiled). 2) Plastic components in the master cylinder. Where the acuator rod meets the master cylinder.
This comes from someone that had the same issues with a Miata.
Thanks....Jeff!
Thanks....Jeff!
