1. Can you manually adjust your boost pressure with the access port or is boost pressure delegated by maps and custom tunes with access tuner software?
2. If you can't manually adjust access port boost pressure can you use a MBC in conjuction with the access port?
3. Are there any cobb tuners in Houston that can tune the access port for our car?
4. Why have some people gotten CEL's after installing the accessport?
