Sooo.... I let my alternator belt go a little too long... and it snapped... luckily was only a mile from home, wasn't too worried... I'd forgotten it also drived the water pump (yikes!).
Figured i'd replace them both while I'm at it.
Read up on it, seems easy enough task, I've done this is plenty of other cars.
But - is there some magic trick to actually accessing the two mounting bolts on the alternator??? Good Good, looks like you need the hands of a 5 year old to reach under there. Especially the lower one - can't even see it, just *know* where it is.Is that one just better reached through the wheel well? Looks like I have some plastic covers in there i'd have to get out of the way.
meanwhile the !@#$ lower bolt on the power steering pump (for the other belt) is really stuck... I can get to it easy w/ box-end or ratcheting wrench, but won't budge... can't *quite* fit extension socket+ratchet w/ enough room to slip a pipe over it.... grrrr....
is that one also accessible from underneath, if i remove the wind guard etc?
Ok ranting over....
Ok ranting over....
