A pic of my GHL tb exhaust.
PlatinumMSP said:
Basically man I bought it off sweetlou69 yesterday and am selling it for the same price because i've had a change of plans and i need the money. I believe the pipe does have flex built into it, i'm not sure what kind of hi flow cat it is but its the same one that comes with all the GHL systems, you wont find a downpipe of better quality, condition, and performance for less money than this.
I had no intention of thread jacking by the way.
IF IT HAS THE FLEX I WILL BUY IT OFF YOU.
WHEN WILL YOU HAVE IT IN YOUR HANDS?
PM ME
THANKS DOUG
edit: it comes with everything you see in the picture man, GHL has a lifetime warrenty on all parts too so you ever have to worry about it
ok to end this thread jack pm me if interested
dman555 said:
LOOKS RAD.
I NOTICED AN O2 BUNG ON THE OLD PIPE.
DO YOU HAVE ONE ONTHE GHL PIPE??
THANKS DOUG
There isnt an o2 bung on the old pipe in that picture unless I missed it when taking it off. To my knowledge ther was only two bungs. One on the exhaust manifold and one between both cats. Correct me if I am wrong.
there is on O2 bung in the stock pipe but it is plugged with a bolt. Look closely right before the heat shield on the J pipe.
My ghl is on the car but it hangas very low in the center. Will kartboy hangers change that? I have already ordered them. It clunks around.... I am sure the kartboy hangers will take care of that but what about the low hanging in the center?
The kartboy hangers will fix that problem. The rubber hangers arent strong enough to hold those big 3 inch pipes in place. You could also try and bend down the hangers themselves, which would raise the piping up a little bit. Bring it on by my house tonight, I'll show you what I am talking about.
Just a thought, if the band clamp connecting your midpipe to your down pipe is not tight enough, it will cause the entire center portion of the exhaust to hang low........... One of the problems with slip fit connections......
so true...
Another problem I am running into is that my oil return line is leaking from somwhere. It doesnt look like it is coming from the seal on the block right above the oilpan. It almost looks like it is coming from the hose itself. Maybe the clamp is not tight enough. It moves around the hose in a circle when it is tight. Any ideas?
are you sure your hose isnt cracked?
the ghl downpipe is a little bit of a pain to install but it is well worth the time and money. I was driving around open downpipe for a couple days and my car sounded beastly. You should expect to see some nice gains with both the ghl and unichip
jflo said:
i need to get that stud fixed, too
what kind of muffler do you have jfo, and does your exhaust go under the rear axle. its hard to tell from your sig but it looks sorta similar to my setup
my GHL turboback just got installed yesterday and its sliding to the right its melting and banging my lip on my car, i have brand new kartboy hangers and every time i realine the thing it just goes back to that spot wtf am i supposed to do!
I put the kartboy hangers on and still didnt help. I am taking it up to midas tomorrow and having them weld a hanger in the middle.
