79-85 RX-7, 94-01 Miata, Factory Race 4.444 Gears, side bearings, pinion seal, crush sleeve NIB - SOLD
Status
Not open for further replies.
2007 MazdaSpeed 3
Mazda 79-85 RX-7, 94-01 Miata, Factory Race 4.444 Gears, side bearings, pinion seal, crush sleeve NIB
New in factory box & wrapping.
$380 +shipping
Newark, Texas 76071
Mazda Factory Race Ring and Pinion Gearset 4.444 ratio in plastic wrap with metal preservative coating
MAZDA Factory Race part number: 1393-27-110A
This part number has apparently been superceeded by M054-27-110A.
The dimensions of the old part number 1393-27-110A are the same as the newer part number M054-27-110A.
Ring gear: 40 teeth
Pinion gear: 9 teeth
Gearset fits RX-2; RX-3SP; 79-85 RX-7; 94-01 Miata; Honda S2000.
All these use this short pinion gear
differential shaft diameters and splines:
7" small axle = 25mm x 24 spline
(2) Carrier side bearings 0221-27-350
D-Code: 27305
marked NTM 32008X
Fits 71-78 12A & 13B; 79-91 RX-7; 94-97 Miata 1.8
Pinion seal 0223-27-018
D-Code: 27018
marked AD2398E NOK
Fits 71-78 12A & 13B; 79-82 RX-7
Pinion Crush Sleeve 0305-27-171 (still in unopened sealed plastic bag)
D-Code 27171
Designation: Piece, Distance
Fits 71-78 12A & 13B; 79-85 RX-7; 87-91 RX-7 Turbo II
Clean, No damage. No corrosion.
All items in boxed storage for 20+ years.
Only opened and removed from protective plastic to take these pictures.
$380 + shipping
Contact for questions: (817) 403-3680
Checking current prices online at http://www.mazdatrix.com/g6.htm
1393-27-110A
The old part# was changed to M054-27-110A
http://www.mazdamotorsports.com/pdfs/catalog/07_Differential_Drivetrain.pdf
RING & PINION 4.444 SHORT NOSE 27-110A-M054
$595.21
(2) Carrier Side bearings 1393-27-110A
Fits 79-92 RX-7
DIFF BEARING 79-92 N/T SIDE CARRIER 27-3500-0221 $50.94
x 2 = $ 101.88
Fits 71-85 all
DIFF PINION SEAL 71-85 ALL 27-0180-0223
$17.32
Pinion Crush Sleeve 0305-27-171 Designation: Piece, Distance
Fits 85 & Older RX-7 and Turbo II
DIFF SLEEVE PINION -85 + TURBOII 27-1710-0305
$15.22
Current cost of all parts: $729.63
My price: $380 + shipping
List Date: 10/18/2013
For more info, click here to view the original listing: 79-85 RX-7, 94-01 Miata, Factory Race 4.444 Gears, side bearings, pinion seal, crush sleeve NIB
Item Has Been Sold.
ga.aspx
Status
