n3rdgen@CS
CorkSport Rep
Adjustable Camber Plates for the 4th Gen Mazda 3 or CX-30 are a great choice if you are looking to fit wider wheels or to improve handling characteristics. The camber plates have been designed to be a direct replacement for your factory strut top mounts, so whether you are running lowering springs or factory springs you can add camber adjustment to your Mazda. The CS Camber Plates also feature solid pillow-ball bearings to provide more feedback while driving. The camber plates offer adjustments ranging from -2.4 to +0.9 degrees so you can find your ideal setting that fits your driving style.
Mazda 3 Turbo Camber Plates allow you to adjust front wheel camber
Setup your Mazda 3 Turbo front camber with the CorkSport Camber Plates
