4 Bolt MSP/626 Brake upgrade
FunkRider
Mazda Protege 1.8 ES 5spd
So I came up with the idea that you can get a set of MSP/626 rotor blanks drilled in 4x100 instead of 5x114.3 you can use the MSP larger front brakes on a 4 bolt car.
The only problem is getting the rotors undrilled rotors and then having them drilled. I wonder if any other 4 bolt brake rotors would have the same size or hat offset.
I have no interest in doing a 5 bolt conversion at this time either. Plus if I did later I'd already have the front calipers.
