<div class="bbWrapper">as a few people mentioned in one of my other threads, a good quote found by HondaEat-R - from garrett directly:<br />
<blockquote data-attributes="" data-quote="" data-source=""
class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">
<div class="bbCodeBlock-content">
<div class="bbCodeBlock-expandContent js-expandContent ">
<b>Internal</b> Wastegates are built into the turbine housing and consist of a flapper valve, crank arm, rod end, and pneumatic actuator. It is important to connect this actuator only to boost pressure; i.e. it is not designed to handle vacuum and as such should not be referenced to an intake manifold.
</div>
<div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div>
</div>
</blockquote>so if youre observant you, youve already realized that the MSP is configured from the factory just the way garrett said NOT to do it.<br />
<br />
a solution i think im gonna try, for all of three dollars:<br />
1.) go to petco<br />
2.) buy <a href="http://www.petco.com/product/7178/Lee-s-Check-Valve.aspx?CoreCat=OnSiteSearch" target="_blank" class="link link--external" rel="nofollow ugc noopener">Lee's Check Valve</a> for $3 (the other one available is a piece of trash)<br />
3.) cut WGA line, install check valve with flow arrow going toward WGA<br />
4.) apply hair spray to barbs, zip tie lines<br />
5.) sleep better at night.<br />
<br />
i have that check valve in use for some of the CF vacuum bagging i do and it holds 22inHg no problem, 100% leak free... it should work in this application as well. the barbs are a shade small for standard 3mm line but will do the trick if youre smart about it.<br />
note that if you have a boost controller, it should operate as an effective check valve. if its a bleeder type im not 100% sure, but the ball-and-spring or solenoid based ones definitely would not require this quick hack.<br />
<br />
just a pointer for those of us who have incorrectly configured WGA's.</div>
