The Great NY
- 2004 Mazda Atenza(6)
In the ongoing quest to make more power with our duratec 3.0L, thoughts of a larger TB has always been on my mind. The mustang modular engines have showed promise thru the use of larger TB's. Which turns into easy bolt on power increases.
I was looking at trying the 4.0L mustang v6 TB. But why try that when our new 6 generation has a bigger TB than the stang.
Anyway, this is basically going to be a joint effort here between myself and Scott(twowheelin) to make it so our 3.0L can use our bigger brothers TB. For comparison the optimized 3.0L TB is only 60mm in diameter. The optimized 3.7L TB is a whopping 72mm in diameter. That is a huge increase over the stock 3.0L TB.
Simply put...more times then not more air means more power capability.
Scott was kind enough to let me use one of the 3.7L TB's from his stock to work on this. Thank you very much scott.
This thread will be a running log of the R&D I will be doing to get this mod a reality. From possibly making an adapter plate as well as seeing how far I can go (if need be) with porting the intake manifold entrance to better compliment the bigger TB.
All updates, testing, and any issues will be posted here as I work on this. So those who are interested in this mods outcome sub up and stay tuned.
UPDATE: (11-19-2010)
received the 3.7L mazda 6 throttle body today. immediately took it out of the package and started measuring.
first things first....the 3.7L TB is huge compared to our regular 3.0L TB, i mean it literally swallows our lil 3.0L TB
first part of the good news is. after measuring and inspecting the bolt pattern. go figure, like Scott and myself suspected there are close. not only are they close, but they are identical
like i said it seems they just made the bore larger but didnt move the bolt holes. if you look at the 3.0L TB you can see how much material there is still between the bolt holes and the bore. they may have just changed the electronics around to facilitate a larger bore.
pins look the same, same exact plug. i'll big going thru the wiring to make sure its all pinned the same and at a quick glance prior to receiving the unit. the wiring looks the same.
here are the pics so you can see what im talking about.
left is 3.0L and right is 3.7L
Left is 3.7L and right is 3.0L
And Heres the 3.7L TB literally swallowing the 3.0L TB
