So I took the CX-5 in to the dealer for the 1st oil change.  Complained about losing oil (they brushed it off), gave them the TSB for the rough shifting (said it wasn't applicable to Canada). I also pointed out an issue I have just seen as well.  From a cold start and just sitting in the driverway, I can see my temp gauge climb fast to almost out of the blue region, then it falls right back down to horizontal, then climbs normally up when driving to just under 100 (but takes forever).  I've never seen a fluctuation on a temp gauge like that.
So, I had to literally put the hard copy of the TSB in their face where it says it's from Mazda NORTH AMERICA and where it says the procedure to fix if in Canada, I have no time to force the issue today, but I will be bringing it up again and this time demanding they do it.
As for the temp surge, then drop, has anyone seen that?
Thanks for letting me vent!
Also, if I need to go over their heads on anything, what is the best way?
Cheers
