Hello everyone, I am writing with question regarding transmission oil replacement. The engine is 2.2d 129kw diesel. We bought the car, it has 190k km on the clock. As far as I know the fluid was never replaced. The question is, should the transmission fluid be changed at that odometer reading? I read on forums here, people suggest at first drain and fill 2-3 times before dropping the pan and changing the filter. Could anyone confirm or deny if that would be the procedure for that? Thanks.
