2007~2015 2013 CX-9 Touring P2A04
podan
2013 Mazda CX-9 Touring
Hello,
My wife's having issues with her 2013 CX-9 Touring (75,000 miles) and I joined the forum hoping for help. I usually work on my older Honda, but leave her Mazda alone.
Yesterday the CEL came on while she was driving. This morning I connected my generic wifi connector and my laptop to see what was going on. The DTC was P2A04, downstream oxygen sensor range/performance.
She took it to the dealership (her choice) and was told she needed 2 oxygen sensors, a catalytic converter, and spark plugs. After recovering from their list of work they wanted to do she brought it back home to me in tears.
I'm not sure where to start on her vehicle, but I do have all the information my scan tool provided that goes with the DTC, but it saved as a .txt file and I don't see how to attach it here. Any help/ideas would be appreciated. Thanks!
For the text file posting here open the file in one of the built in text editors that came with your computer (Notepad or the like), "select all" for the text and cut/paste it here. Once you do that perhaps the other folks here on the site can chime in.
Oh yeah. Duh!
This report is generated on: 2019-5-2 6:19:53
Vehicle VIN: JM3TB2CA9D0407299
Pending DTCs
P2A04
O2 Sensor Circuit Range/Performance Bank 2 Sensor 2
Active DTCs
P2A04
Freezeframe: 0 DTC: P2A04
FT86 engine oil temperature
-40.00 C
-40.00 F
Fuel system 2 status
NODATA
Fuel system 1 status
Closed
Calculated engine load value
61.96 %
Engine coolant temperature
80.00 C
176.00 F
Short term fuel trim - bank 1
3.13 %
Long term fuel trim - bank 1
4.69 %
Short term fuel trim - bank 2
1.56 %
Long term fuel trim - bank 2
3.91 %
Engine rpm
1677.25 RPM
Vehicle speed
20.00 KPH
Vehicle speed
12.43 MPH
Ignition timing advance for cylinder 1
28.50 Deg
Intake air temperature
28.00 C
82.40 F
Air flow rate from mass air flow sensor
29.60 g/s
Absolute throttle position
22.75 %
Oxygen sensor output voltage bank 1 sensor 2
0.12 v
Short term fuel trim associated with O2 sensor bank 1 sensor 2
99.22 %
Oxygen sensor output voltage bank 2 sensor 2
0.00 v
Short term fuel trim associated with O2 sensor bank 2 sensor 2
99.22 %
Time since engine start
421.00 sec
Commanded Evaporative Purge
25.10 %
Fuel Level
92.16 %
Number of warm up since DTC cleared
255.00
JK 2012~2017 auto transmission fluid temperature
OOR C
Distance traveled since DTC cleared
20998.00 KM
13050.34 Mile
EVAP system vapor pressure
OOR Pa
2.36 Psi
Barometric Pressure
96.00 kPa
Barometric Pressure
13.92 Psi
Oxygen sensor output current bank 1 sensor 1
0.06 mA
Oxygen sensor equivalence ratio bank 1 sensor 1
1.02
Air to fuel ratio from wide range oxygen sensor bank 1 sensor 1
15.01
Wide range oxygen sensor output current bank 2 sensor 1
0.05 mA
Wide range oxygen sensor equivalence ratio bank 2 sensor 1
1.01
Air to fuel ratio from wide range oxygen sensor bank 2 sensor 1
14.85
Catalyst Temperature Bank 1 Sensor 1
634.30 C
1173.92 F
Catalyst Temperature Bank 2 Sensor 1
634.30 C
1173.92 F
Control Module Voltage
13.84 V
Absolute load value
43.92 %
Commanded equivalence ratio
1.02
Relative throttle position
10.20 %
Ambient air temperature
28.00 C
82.40 F
Absolute Throttle Position B
34.51 %
Absolute pedal Position D
26.27 %
Absolute pedal position E
13.33 %
Commanded throttle actuator control
16.08 %
Hello,
Couple things:
1. It's probably just a bad O2 sensor.
2. If it really is a catalytic converter, those are warranted for 8 years/80,000miles by federal law (read this, jump to page 4: https://nepis.epa.gov/Exe/ZyPDF.cgi/P100NNQH.PDF?Dockey=P100NNQH.PDF)
In short, you went to a garbage dealer that is trying to defraud you.
