For Sale 2011 CX9 AWD GT
2011 CX9 awd Grand Touring. 214k miles. Pearl White.
It is starting and running. But, it needs to tow. The alternator locked out and serpentine belt ripped. I do not have time to change the alternator. I bought another car for wife.
I bought the car in 2018 with 150K miles on it and well maintained.
Awd does not engage. I remember that I posted on a post. It is FWD now.
Last transmission service was done around 160k with mazda oem fluid for twice. Also drain plugs.
I was changing the transfer case fluid every 20k until awd broke. I was changing the rear differential fluid every spring.
Spark plugs&coils: replaced around 160k
Power steering fluid: replaced around 160k and last change was in 2022 october with high pressure line
Calipers replaced in 2023 with fomoco and I painted them with primer and caliper paint before install.
Exhaust pipe and mufflers replaced early 2022. No exhaust tips. Catalytic converters are still oem and no issue.
Rear wheel bearings: replaced around 190k. The car has been sitting on driveway since september 2024. There is humming noise from back but it may related with tires(2020)
Blind spot monitor works fine. When I replaced rear radars in 2020/21, i had sealed them with silicone.
Xenon bulbs should be 1 year old.
Engine light is on because of small leak on evap system. It seems like gas cap issue. After replacing the gasket on gas cap, it goes away.
Interior:
Seats are in good condition. Heated seats and memory work fine.
Buttons on steering wheel work fine.
AC works fine(front&rear)
Heads up unit has a message on it. But radio or other input can handle via button on steering wheel.
Dvd player works. I believe I still have bluetooth headphones.
Keyless works fine. It has only 1 fob with metal key.
i am asking $2500 as is. Located in West Milford,Nj
