[2010] The manual doesn't go past 60,000 miles for maintence?
LordJezo
Am I looking somewhere wrong or am I blind?
The Mexico and other sections go much higher but for the USA schedule 1 maintenance I am only finding listings up to 60,000 miles.
Hopefully I am just very confused. Where do I find the info?
The way I read it, you repeat the schedule after that every 60K.
Hmm.. does it mention spark plugs?
I will have to compare it to the Euro model and see if things start to change after. I wonder why they wouldn't put a complete maintenance list in there for the USA but have one for other countries.
Platinum tipped spark plugs last 100K.
Other fluids like coolant, power steering, brake, etc. you can come up with your own schedule, depending on how much you are willing to shell out for the longevity of your CX9.
Fan belt probably should be replace at schedule as well (like 60K or 75K).
I do differential fluid on 30K schedule. Transmission on 30K/15K schedule.
I also worry about transfer case oil inside, but need to check with dealer if they do that.
