2010 Porsche Boxster Spyder
mikeyb
Contributor
01 BMW 325xi Touring
Porsches current two-seater roadster, the ever-popular Boxster, is to get a performance makeover for the final few years of its life, when a faster, lighter and more hardcore version called the Boxster Spyder hits UK showrooms.
The Boxster Spyder, revealed in these official Porsche images, will make its motor show debut at next months Los Angeles Auto Show, before going on sale in the UK in February 2010. The location of its unveiling is a clever one; stripped-out Speedster versions of the Porsche 356, and of various 911s, have found an eager following on the west coast of America over the years.
Based on the current Boxster S, the Spyder will become the third and ultimate version of the car; its no limited-run special edition. It gets modest power and torque hikes over the Boxster S, running instead the same 3.4-litre engine and tune as the current Cayman S, which develops 315bhp at 7200rpm and 273lb ft at 4750rpm.
Contributing just as greatly to this cars improved performance will be the weight-saving regime Porsche has put it though. The Spyder is 80kg lighter than a regular Boxster S, and its 247bhp-per-tonne power-to-weight ratio compares impressively to that of a regular Boxster S (227bhp-per-tonne), a Cayman S (233bhp per tonne) - even an entry-level 911 Carrera (241bhp-per-tonne).
There are signs of that weight-saving programme all over this car. Up front, the regular Boxsters daytime running lights and fog lamps have been removed and blanked off. At the rear, the cars automatic roof system has been completely taken out, replaced with a lighter, manually-operated canopy-style roof and new double-bubble style rear deck.
Porsches weight-saving programme leaves an equally noticeable legacy inside the Spyders cabin. A pair of lighter and more supportive bucket seats take the place of the standard Boxster S chairs, and belt-like door pulls replace the regular cars interior doorhandles. There is no air conditioning as standard and no CD/radio, although buyers will be able to option these systems. The car does feature electric door mirrors and electric windows.
Equipped with Porsche PDK double-clutch gearbox and Sport Chrono Plus package (which includes the all-important launch control), the Boxster Spyder will crack 62mph from launch in just 4.8sec two tenths of a second quicker than a standard S. Its slightly more fuel efficient than a Boxster S too, although because its roof must be removed for top speed runs, it has a higher co-efficient of drag and a slightly more modest top speed of 166mph.
The Boxster Spyders chassis will have a more focused, sporting specification and set-up than a Boxster S, although exact details on that remain to be confirmed. Expect a lower ride height, stiffer springs and anti-roll bars, and fixed rate dampers weighing less per corner than Porsches sophisticated PASM dampers.
Exterior design flourishes unique to the Boxster Spyder include restyled air intakes in its front valance and on its flanks, a new high-level brake light at the rear and an extended rear spoiler. On the inside, a body-coloured transmission tunnel and fascia accent set the car apart
A lot better looking than previous models....doesn't look like a fake Porsche or anything lol, it does have slight fighter jet characteristics.
That's a boxter I would drive. The previous versions just looked odd. I wonder how the car looks with the top up.
Two things:
I don't like the tonneau top.. It looks awkward.
Second, Fog, change your sig.. That gif is over 1 meg.
true true.... then are some cars that look good with the top up or down: MX-5 PRHT
Not saying that there aren't those that look good with the top up as well. Just that in a convertable, the design language is such that they are supposed to look good with the top down...and then have a top you can put up when it's too cold or raining, looks of the top are typically secondary. 'Course there are some that don't even look good with the top down *cough350Zcough*
Definitely sexy with the roof off. Looks terrible with the canopy on though.
R
Porsche Boxster Spyder (2010) CAR review
Is the new Porsche Boxster Spyder the best Boxster you can buy, or the worst? Rather than being a stickers and stripes special edition, or an expensive limited-run like the 911 Sport Classic, the Spyder joins the Boxster range as a third model. And it features some clever weight saving tech that cleaves 80 kilos from the kerbweight at 1275kg its the lightest car Porsche currently makes while theres also more power and Carrera GT-inspired looks.
But Porsche calls this Boxster a Spyder because its lost the regular cars folding fabric roof, a roof than made it a great everyday car. Has the sacrifice to make the Spyder a sharper drivers tool been worth it? Read our first drive of the new Porsche Boxster Spyder to find out.
How has the weight been cut from the new Porsche Boxster Spyder?
The aluminium doors save 15kg, the one-piece rear deck made from the same stuff cuts another 3kg, and carbon-backed bucket seats trim 12kg. The new ten-spoke wheels are the lightest set of 19-inch wheels that Porsche make, weighing less than ten kilos each, and the lower side windows also helps shed a few pounds.
The lack of an electrically folding fabric roof also helps cut weight. The new cap as Porsche calls it weighs less than 6kg, and the carbonfibre frame that supports it is 5kg. The roof clips onto the windscreen header rail, and two hooks fasten onto the rear deck, and when you close the new Carrera GT-style boot, it acts as a lever to pull the roof taught. Top speed is limited to 124mph with the roof in place, but lifted to 166mph without it.
Theres also lower and thus lighter side windows, new front bumper with LED lights, black mesh inserts for the side intakes, a plastic wind deflector between the seats, a high-level third brake light, and a larger fixed rear spoiler.
Inside the Spyder you wont find a radio, air-con, cup holders or door pockets, though you can spec the sound system and the beverage holders back in at no extra cost. And you can choose the less extreme (i.e. heavier) sports seats if you want. Fabric door pulls, red seat belts, the lack of a cowl for the instrument clusters, plus the transmission tunnel in the same colour as the exterior, completes the makeover.
Statistics
<table><tbody><tr id="ctl00_placeHolderContainer_placeHolderMainContent_placeHolderColumn02_placeHolderColumn02Body_Statistics1_rowHowMuch"> <th>How much?</th> <td>44,643</td> </tr> <tr id="ctl00_placeHolderContainer_placeHolderMainContent_placeHolderColumn02_placeHolderColumn02Body_Statistics1_rowOnSale"> <th>On sale in the UK:</th> <td>2010</td> </tr> <tr id="ctl00_placeHolderContainer_placeHolderMainContent_placeHolderColumn02_placeHolderColumn02Body_Statistics1_rowEngine"> <th>Engine:</th> <td>3436cc flat-six, 316bhp @ 7200rpm, 273lb ft @ 4750rpm</td> </tr> <tr id="ctl00_placeHolderContainer_placeHolderMainContent_placeHolderColumn02_placeHolderColumn02Body_Statistics1_rowTransmission"> <th>Transmission:</th> <td>Six-speed manual, rear-wheel drive</td> </tr> <tr id="ctl00_placeHolderContainer_placeHolderMainContent_placeHolderColumn02_placeHolderColumn02Body_Statistics1_rowPerformance"> <th>Performance:</th> <td>5.1sec 0-62mph, 166mph (roof off), 29.1mpg, 228g/km CO2</td> </tr> <tr id="ctl00_placeHolderContainer_placeHolderMainContent_placeHolderColumn02_placeHolderColumn02Body_Statistics1_rowWeight"> <th>How heavy / made of?</th> <td>1275kg/steel</td> </tr> <tr id="ctl00_placeHolderContainer_placeHolderMainContent_placeHolderColumn02_placeHolderColumn02Body_Statistics1_rowSize"> <th>How big (length/width/height in mm)?</th> <td>4342/1801/1231</td></tr></tbody></table>
CAR's rating
Handling
Performance
Usability
Feelgood factor
Readers' rating
What about the power? And how improved is the performance?
The direct-injection 3.4-litre flat-six is the same size as the unit in the Boxster S, but the engine in the Spyder is actually tweaked to the slightly hotter Cayman S tune. It means peak power output is actually achieved at 7200rpm, 950 revs above the maximum engine speed of the Boxster S. And rather than the Boxsters spread of 266lb ft from 4400-5500rpm, the Spyder produces 273lb ft at 4750rpm.
Stick with the standard manual gearbox and the Spyder will hit 62mph in 5.1 seconds, 0.2sec quicker than a Boxster S, although its slower flat out thanks to the lack of a roof. Go for the seven-speed, dual-clutch PDK box and youll manage five seconds to 62 (4.8 if you use launch control), 163mph, 30.4mpg and 218g/km and you can choose proper paddles over the awful rocker switches
Theres also new sports suspension, incorporating shorter, stiffer springs, firmer dampers, and new front and rear anti-roll bars. Thanks to a 20mm drop in ride height, and the lack of bulk from the lightweight roof, the Spyders centre of gravity is 25mm lower than in the Boxster S. Braking is by 318mm discs up front and 299mm discs at the rear, 350mm ceramic stoppers are available if youre really keen, and a proper mechanical diff is also standard.
Just how practical is it?
Well Porsche says the Spyder has been developed first and foremost for driving in the open air, which tells you just about all you need to know about this cars usefulness in the UK whens the last time you saw a convertible with its top dropped? And the regular cars rear boot has gone thanks to that new decklid. You can still store luggage underneath but you need to lift the whole section of rear bodywork up to do it.
Whats it like to drive?
Like a Boxster S but with an added kick. The combination of the Caymans extra 10bhp and an 80kg weight reduction make acceleration feel more urgent, and the sports exhaust just adds to the effect. Any lingering criticism that the Boxster is a poor relation to the 911 when it comes to performance is banished when you flatten the right pedal. You dont have to thrash it either, the weight reduction magnifying mid-range torque, although youll want to wind it out simply for the side effects.
The handling feels equally improved. The communicative, if slightly leisurely steering, is as positive as ever, but the Spyder seems that much more alert and keen to change tack. Obviously the drop in kerb weight plays a massive part here but you can also thank the sports suspension for that; you certainly wont be thanking it when you get to a rough bit of road: the ride is solid and theres no electronic facility to back off the dampers and calm things down because the PASM adaptive dampers went in the same bin as the cupholders.
The bucket seats are at least fabulously comfortable and the driving position excellent so it takes little time to get comfortable. Not so speedy is the roof-up process. The tent of a roof isnt quite as nasty to use as wed feared but it still takes a couple of minutes to put in place. We werent able to test it for rain resistance but can report that wind noise behind your head is authentically 1950s Speedster.
Verdict
The Boxster Spyder is mixed bag: stacks of fun but with a very narrow appeal. On the one hand its genuinely better to drive than the standard car having been on a proper diet, its faster and more focused and just looks and feels that bit more special than the Boxsters you see every day. If you lived in sunny California and had another car in the garage for sensible duties, wed say go for it, providing you can stomach the brittle ride. But for those of us subjected to a more varied, okay awful, climate, the Spyder will remain a Lotus Elise-style Sunday fun car at best, and the Boxster S (plus a few choice options) still the best way to spend your money.
